このページのスレッド一覧(全6スレッド)
6 | 1 | 2020年10月10日 10:03 |
16 | 3 | 2015年3月13日 20:17 |
39 | 9 | 2013年4月29日 23:30 |
4 | 0 | 2013年4月17日 14:36 |
12 | 3 | 2012年7月19日 17:31 |
26 | 3 | 2012年1月8日 16:48 |
The RICOH MP 2501SP Laser Multifunction Printer is a versatile A3 mono MFP for committed working groups. Featuring class-leading features, it delivers impressive productivity and low operating costs. A color scanner, automatic duplex printing and a copy of the ID card are standard. And, for ease of use, there's an intuitive color touch screen. A GWNX driver and an optional hard drive add everything from secure printing to solution integration. Whether alone or in a managed fleet, the MFP provides the flexibility to transform document processes. Now or in the future how your needs change.
The RICOH MP 2501SP gets through fast work. With a print speed of up to 25 ppm, large jobs are completed quickly. And a first page in 5.5 seconds saves you from waiting. Color scanning extends productivity benefits to digital workflows.
Smart design maximizes efficiency. A touchscreen provides quick, one-touch access to MFP features and custom workflows. The front access and remote management features can help you quickly troubleshoot issues. And a safe cube design and space support allows you to place the MFP where it's needed.
The Ricoh MP 2501SP Multifunctional B&W Laser Printer is cheap and economical. Low total energy consumption keeps electricity bills low, and automatic two-sided printing saves paper. Further savings come from user quotas and secure printing. An eco-friendly display encourages good practices by monitoring paper savings.
The 4.3-inch color touchscreen gives you quick access to key features. It's tilted and customizable with your company's logo and your choice of icons. Or customize it for each user. A built-in SD/USB slot allows PC-free printing from removable storage devices with an optional hard drive installed.
The solution-ready GWNX controller provides high-end functionality for RICOH MP 2501SP. Integration with integrated server-based solutions to streamline processes and improve device management. Or increase productivity by applying the same interface to all MFPs on your network.
Get more out of your investment with the optional hard drive. Use it for secure printing. To customize the splash screen for each user. Or to preview files when printing from USB storage devices. Encrypting and overwriting the hard drive ensures data security.
The color scanner improves document processes. Scan to email, folder or USB. Or PDF-A for archiving. For one-tap jobs, add a GlobalScan NX icon to the control panel. Scan previews provide the confidence that a document is being scanned correctly.https://webllena.com/ricoh-mp-2501sp-multifunctional-bw-laser-printer-review/
パソコンの所に英会話教室の感想貼っているやつらと同じ系統かな?
書込番号:23716514
プリンターは、「キャノン MG3230」です。
給紙が上手く出来なくなったので、「ELECOM プリンタクリーニングシート(両面タイプ) CK-PR1W」を評判を聞いて購入しました。
http://www.elecom.co.jp/photo/p21/CK-PR1W_21.jpg
いざ使用してみようとすると、「空送り」の方法が分かりません。
プリンターのプロパティにもそういった機能が無いのです。
白紙のA4用紙でもコピーすれば空送りの替わりになってくれるのでしょうか?⇒これはちょっと不安でやっていません。
どなたか空送りの方法をご教示ください。
白紙のコピー → 薄くグレーのコピー・・・何てこともあるかも,
ガラス・保護マットに汚れがなければ,原稿なしでコピー 実行 OK!
一太郎,ワード 等でA4画面に何も入力せず,改行のみ実行・・・・
これで印刷を試行すれば・・・
メンテナンス → ローラークリーニング で可能かと・・・
ただし,給紙ローラーが摩耗します。
書込番号:18573809
答えじゃ無いかも知れないですけど
http://cweb.canon.jp/e-support/faq/answer/inkjetmfp/69228-1.html
普通紙の変わりにクリーニングシートを使っては
後はWordpad等で何も書かない白紙で印刷するですかね
ただこの方法だと1と小さく印刷されますが
昔私はそうしていましたよ
書込番号:18573837
皆様、書き込み有り難うございます。
実は何も知らず給紙ローラーのクリーニングをかなりやってしまいました・・・
摩耗するなんてっ!
知らなかったです。。。
沼さんの方法で両面白紙印刷でやってみたいと思います。
有り難うございましたm(_ _)m
書込番号:18574506
私はキャノンmg6230のプリンタを使っていますが、購入当初から互換インクを使用しています。純正インクがあまりにも高く、インク3〜4セット分位でで元が取れると思ったからです。(プリンタは14500円で購入しました)
最初に買った互換インクは粗悪品で、黒が全く出なくなり、また、他のカラーインクも一部出なくなったり、インクがあっという間になくなるものがありました。安物買いの銭失いかと思いましたが、ヘッド洗浄液やヘッドクリーニングでなんとか元に戻りました。
その後、ノーブランドではなく、製造メーカーが日本の会社の互換インクを使ってから何のトラブルもなく動作しています。
さて、質問ですが、互換インク関連で、次回トラブルが発生した時の対処として、皆さんはどの様な対策(未然に防ぐ対策や、トラブルが発生した時の回復経験など)をお聞かせください。
この質問は、互換インクを使用するという事を前提とした質問ですので、純正を使うべきだという回答はしないでください。私の経験では、次のことに気をつけています。
@互換インクは、ノーブランドではなく、ちゃんとした、メーカーのものを買う。(325、326の6色セット1000円以 下で良いものがありました。)
Aインクタンクの取替え時には、黄色のテープを取ったあとに、空気穴が正常に空いていることを確認する。
Bインクの減りが、あまりにも早い互換インクは、直ぐに捨てる。
Cすこしの色の変化(暗いなど)はプリンタの設定で輝度、コントラストの調整である程度は直ります。
Dプリンタヘッドが目詰まりした場合は、洗浄液をプリンタヘッドのインク受け口に垂らす。(mg6230ではプリンタヘッ ドが外れないように思います。はずし方を知っている人があれば教えてください。
では、みなさんの経験を投稿していただけることを楽しみにしています。
女郎花さん
わたしはMG6230ユーザーではありませんが、キヤノンのインクジェットプリンターを4機種使ってきた経験があり、今も3台保有しています。
さて、MG6230は、写真を見る限り、他のキャノン機と同様に、灰色のヘッド固定レバーを上に上げると、簡単に取り出せる構造のようです。
全てのインクタンクを取り外してから、ヘッド固定レバーを上げて、ヘッドを外してみてください。
わたしのヘッド洗浄方法は、マジックリンをお湯で希釈した液体に浸けて数時間置く、というものです。
長期間、使用しない場合にもヘッドは洗浄し、乾燥させて、ラップして、保管しています。
プリンターはとても安く、インクは高額ですので、プリンターの予備機・代替機は、できるだけ、同一型番のヘッドが使える中古プリンターを調達するか、インクタンクが同一型番のヘッドを持つプリンターを調達しています。
このため、10年近く、同じ型番のインクと互換のインクを使っています。
値段優先で、ノンブランドの互換インクを使っていますが、そのためにプリンターが早く故障した経験はありませんが、壊れれば、プリンターを買い換えるつもりですから、プリンターが壊れる心配はしていません。
書込番号:16071475 スマートフォンサイトからの書き込み
女郎花さん おはよう御座います。 去年、MG6230を買いました。 用途は年賀状と暑中見舞い。枚数は20枚程度。
デジカメはパソコンに圧縮して保存、時々DVDに焼きます。
買い換え前に貰い物のプリンターを使ってました。
ある時、ダイソーの補充液買って使いました。その時は良かったけれど半年後に色化け。
慌てて純正カートリッジに交換。何度もテストプリントしていると復活しました。
なるべくプリントしない方針です。
@互換インク、、は為になりました。
papic0さんの
も為になりました。
もし、色化けしたり不具合起こした場合 単機能の安価なプリンターに買い換える積もりにしてます。
書込番号:16071707
BRDさん
単機能プリンターがほとんど販売されなくなっています。
あっても、インクタンクが全色(または複数色)一体型で、1色でも無くなると、インクタンクを交換する方式で、インクを多消費せざるを得ない仕組みです。
インクヘッドが一体型のインクタンクになっており、わたしにはヘッド洗浄ができません。
互換インクを使う場合には、詰め替えインクを使い、ヘッドが目詰まりを起こした時点で、ヘッドを交換するために、純正インクを購入することになります。
ヘッド一体型インクタンクの洗浄方法があるかも知れませんが、わたしには知識がありません。
書込番号:16072181
papic0さん そうなんですよね〜
老眼なので木版画も彫れなくなったし、郵便局の赤いゴム版で済ますか、いっそ 賀状止めましたと通知出すか?
年寄り同士なので skype出来る友もほとんど居ません。
レーザープリンターが以外と安くなってますね。
書込番号:16072219
papic0さん
非常に貴重な情報ありがとうございます。
MG6230のインクタンク部分の写真をアップします。従来あった灰色のヘッド固定レバーがなくなっています。灰色の固定レバーのようなものは、インクタンクを囲んだ構造物のようなものに変わっています。ネットで色々調べましたが、MG6230のプリンターヘッドは外せるという記述のものと、外せないとという記述のものがあります。あまり、触って壊れたら大変ですので本当にヘッド洗浄が必要になるまで、分解を保留している状況です。
マジックリン・・参考になりました。確かに油性を溶かすな力は強いですね。やはり、ヘッド洗浄、ラップなど、予防的なメインテナンスを行っているわけですね。勉強になりました。
BRDさんも書き込みありがとうございます。ダイソーの互換インクが半年で変色したということですが、私の想像の域を超えませんが、インクタンクに入ったインクが半年位で劇的に変色すると思えませんので、やはりヘッドの目詰まりが原因ではないかと想像します。プリンタヘッドの洗浄でも直ったのではないかと想像します。いかがでしょうか?
書込番号:16073234
女郎花さん
わたしは本機種のユーザーではないのですが、本機種の取説の、インク交換のページには、ヘッド固定レバーという言葉が使われています。
固定レバーという言葉が使われている以上、ヘッドは取り外し可能ではないかと考えました。
もっとも、取説が間違っている可能性もあります。
書込番号:16073318 スマートフォンサイトからの書き込み
女郎花さん 犯人は 私でした!
MG6230を買って実際にプリントして操作方法も分かってから、原因は何だったのか?
古いプリンターをバラして見ると、調子に乗って補充インクを入れすぎたからでした。
ヘッドにインクがべっとり。
シンナー使わず灯油か何か使って洗ったと思います。
何度も何度もテストプリントしていると、次第に良くなっていきました。
でも、純正カートリッジに全部交換しても無駄になるし、さらにバラして底面にあるインク溜め、、ですね?
おしめの様に吸い込む物があって これだな? と確認。
組み立てて、無料回収に出しました。
プリンターは PIXUS 560i だったと思います。
http://cweb.canon.jp/cgi-bin/pixus/supply/product.cgi?pr=pixus560i
書込番号:16073352
papic0さん
プリンターヘッド取り外せました。
灰色の固定レバーのようなものでインクタンクを囲んだ構造物はやはりプリンタヘッド固定レバーでした。
papic0さんが、「本機種の取説の、インク交換のページには、ヘッド固定レバーという言葉が使われています。」との情報よりもう一度見直しますとコノ字型のレバー全体が持ち上がり、プリンタヘッドが外れました。(写真)
本当にありがとうございました。これで、プリンタヘッドの洗浄が楽になりました。
ただ、インクタンクを全て外した後にもう一度取り付けますと、2つのタンクのインク残量が1目盛づつ下がりました。お笑いですね。
書込番号:16075003
女郎花さん
ヘッド固定レバーをあげた状態の写真を掲載していただいて、ありがとうございます。
わたしは、7e、9BKインクにこだわってプリンターを買い換えていますが、機種を変更するときの参考にさせていただきます。
書込番号:16075083 スマートフォンサイトからの書き込み
NewSoft CD Labelerを使い始めました。テキストを入力するとすべて縦書きになってしまいます。むろん、オブジェクトを90度回転させて「立てる」ことはできますが、いわゆる「横書き」ができません。そもそもそのようには作られていないのでしょうか?
EPSONのEP-804の詰め替え用インクを探しているのですが、
エレコムの詰め替え用インク購入しようとしているのですが、対応機種にEP-804がなかなか載っていないので、どれを購入していいのかわからず困っております。
今canonのMG6230と迷っているのですが、詰め替え時に純正のカートリッジが黒いケースの為、どこまでいれたのかわかりずらく、こぼれそうになる様なので、エプソンにしようか悩んでいます。
EP-804は本体についてくるカートリッジは透明なのでしょうか?
実際、詰め替えインクを使われてみえる方に、どちらの方が詰め替えしやすいかなど、アドバイス頂けましたら幸いです。
エプソンIC50カートリッジを有効に再利用できる、詰め替えインク6色と専用工具
http://www2.elecom.co.jp/paper/ink/epson/the-50kitn/
EP-804シリーズ A/AW/AR
http://www2.elecom.co.jp/support/ink/index.asp
上記にエレコムの詰め替え用インクが載ってますけど、店舗に無いのかな?
書込番号:14827250
早速のご回答有難うございます。
やはりTHE-50KITNでよいのですね。
対応機種に型番が載っていないので(インク発売後のパソコンなのでしょうか…)本当にこれでよいのか不安で、質問させて頂きました
EP-804を使ってみえる方で、実際に使ってみえる方はみえますでしょうか?
書込番号:14827324
詰め替えインク使うと保証消えるけどいいんですか?
それとEPSONのインクは代々アイボリー?っていうんですかね グレーっぽいケースに入っていてCanonよりも中身見えなくなってますよ
Canonなら確か一部透明ですよね
書込番号:14828319
PMDBU3を利用できるプリンタでは、BT-MicroEDR2Xが互換動作できるものが多いようです。
書込番号:13973736
永遠の初心者(−−〆) さん、早速のご返信ありがとうございました!
入手したら、また結果報告します!
書込番号:13979246
本日、planexのBluetoothアダプタを購入しました!
BT-MicroEDR2Xが店頭になかったので、BT-MicroEDR1Xにしました。
ジョーシンで980円でした〜
早速帰宅後に設定し、試し刷り。
年賀状の宛て名印刷は、USBケーブルで接続した場合と同じくらい早かったです!
これで、いちいちノートPCを移動しなくても済むかと思うと、
980円はお安い!
情報をありがとうございました!
あとは、PM-A820でスキャンしたデータがPCに飛んだらいいんですが、
そんな機能はなさげです…残念!
書込番号:13996365
【欲しいものリスト】メインアップグレードv4.22
【欲しいものリスト】NEW PC
【Myコレクション】からあげU20例
【欲しいものリスト】あつおくん新PC
